Subject: Tab Menu
rogerg1967
22 Sep 2007 9:34 AM
I am trying to create a tab menu using gif images. I have saved the tab as an image, which works fine for buttons that don't have submenus. The buttons that do have submenus don't show the gif image. Can anyone help me please?
25 Sep 2007 2:31 AM
 Which menu are you using?  Do you have a live URL we can look at as it much easier to troubleshoot this way?  You may want to check out this tutorial which outlines all of the methods I use for finding solutions: Troubleshooting DotNetNuke Skins Thanks,
rogerg1967
25 Sep 2007 4:30 PM
This is a link to the site I am doing.
http://domain1664726.sites.fasthosts.com/
26 Sep 2007 9:58 AM
It may seem like a silly question, but have you tried adding the image details to the submenu class?
.main_dnnmenu_submenu {
    background-color: #cad5ea;
    z-index: 1000;
    cursor: pointer;
    cursor: hand;
    filter:progidXImageTransform.Microsoft.Shadow(color='#696969', Direction=135, Strength=3);
    padding: 1px 1px 1px 1px;   /*explicitly set padding for sub-menus */
background-image: url(button_off.gif);
rogerg1967
26 Sep 2007 12:02 PM
HI,
Not a silly question, this is what is giving me the background on the list of submenu items.
rogerg1967
26 Sep 2007 4:25 PM
This is now driving me maddd!!!!!
Could this be down to the default style? or do i need to add a solpart menu?
26 Sep 2007 11:35 PM
Mdy experience has been that it's almost always in the styling.
