Subject: Good forum module?
mattfarmer
21 Sep 2007 9:27 AM
I am developing a new website and i am thinking about putting a forum on line.
Does anyone have any recommendations for a good module?
I was wondering what forum dnncreative use, and it seems very user friendly.
Thankyou,
Matt
www.six-strings.com
21 Sep 2007 9:51 AM
We use the activeforums module available from activemodules
Forums > Users Lounge > Everything Else > Good forum module?
