Subject: Login Missing II
dbayerdorffer
13 Sep 2007 12:43 PM
I'm new here and to DNN. For some reason, when I logged out to look at my progress recently, I couldn't seem to log back in to make further edits. I still have the login link, but nothing happens when I click on it.
There was a post back in August by wtgmvgwsg, who seemed to have a similiar problem, but the post didn't really give a hands-on solution that I can comprehend.
Can someone please tell me exactly how to get the login option back?
Any help is much appreciated!
dbayerdorffer
13 Sep 2007 2:55 PM
Hi again!
I found the answer in John Mitchell's (mostly DotNetNuke) Blog.  http://blogs.snapsis.com/PermaLink,guid,05e0a045-4944-4f85-aa12-ac9cb774e2fb.aspx
It worked like a charm  :-)
13 Sep 2007 5:43 PM
I think that you'll find that snapsis.com is a good place to visit regularly. John has some nice forums that support DotNetNuke, too.
Forums > Users Lounge > Everything Else > Login Missing II
