Subject: copyright information within html
dnnuknewbie
10 Sep 2007 6:19 AM
I have noticed that the copyright information on DNN is inserted at the top of all the html pages within our dotnetnuke site.  (see below).
I read somewhere that its not a requirement to keep this in, so long as no claim is made to the ownership of the code which is fair enough.
My question is how do i remove it from the top of the page. I am happy to leave it in but surely its is going to affect SEO efforts so near to the top of the html pages.
Thanks. H
10 Sep 2007 7:41 AM
I have just added this post to the quick tips section: How to remove the copyright notice
dnnuknewbie
10 Sep 2007 10:38 AM
Thanks Lee, would you be so kind to recreate that link. I can't seem to see the quick tips at the end of it.
Thanks. H
10 Sep 2007 11:03 AM
http://www.dnncreative.com/Forum/tabid/88/forumid/12/postid/6092/view/topic/Default.aspx
Forums > Users Lounge > Everything Else > copyright information within html
