Subject: Email Templates & Bulk Send
Marcusw
09 Sep 2007 9:47 AM
I need to create an email template from a PDF file and then enable my client to be able to add and edit the content and automatically send it to a client list.
I'm considering using something like ByDesigns Email and Template manager and then setting up a simple DNN website where my client can modify the template and send it.
Has anyone got any suggestions or used any similar products?
The email template needs to be CSS based and web standards compliant.
Marcus
15 Sep 2007 10:19 AM
Did you find a solution?
Marcusw
16 Sep 2007 11:02 AM
Hi Joe,
I'm still investigating this one. I want it to be multi threaded and needs to have anti-spam functionality it?
I'll try to remember to keep you posted as I go on....
Regards,
Marcus.
Forums > Users Lounge > Everything Else > Email Templates & Bulk Send
