Subject: exchange links module
dnnuknewbie
05 Sep 2007 6:07 AM
Greetings,
I am seeking a solution to enable a fast means of link exchange. I want to allow site owners to add in details of their sites so I can review and if appropriate enable them on our site.
Any ideas. Thanks. H
eureka
05 Sep 2007 6:23 AM
Hello H
I understand that this can be achieve using the XMOD module, if you browse on the form and template exchange page you will locate the code to copy and paste.
Lynn
Forums > Users Lounge > Everything Else > exchange links module
