Subject: Places to go for help/Questions
quatrian
03 Sep 2007 4:32 PM
Hi everyone.   I'm just starting out in the DNN world and was wondering if there were any good places to find quick answers to questions.
Is there an IRC chat channel that is sometimes populated?
Is there a list of DNN tokens available anywhere?  I can't a help manual and google doesn't turn up anything.
One of my actual DNN questiosn is:
When I'm doing SQL statements in DNN, how do I make it so I can call SQL functions?  For me, this works:
INSERT INTO DateIndoo (date)
VALUES ('5/2/3402 13:00:00')
where
VALUES (CURDATE())
does not.  However I found the CURDATE() statement listed here: http://dev.mysql.com/doc/refman/5.0/en/date-and-time-functions.html
Any thoughts?
03 Sep 2007 8:09 PM
For DotNetNuke, here are my favorites:
  • Here:  DNNCreative.com
  • DotNetNuke.com
  • Snapsis.com
  • MitchelSellers.com
For DotNetNuke skin tokens, I can't think of a better place to look than DotNetNuke Skinning
Reference Book
To answer your question about doing SQL in DotNetNuke, I would suggest that you take a look at Michael Washington's blog at the DotNetNuke site.  I'm not sure that I can answer your question about CURDATE() in MSSQL.  Try this:
Declare @today datetime
set @today = curdate()
Insert Into DateIndoo(date) Values( @today )
Forums > Users Lounge > Everything Else > Places to go for help/Questions
