Subject: Register Missing
dinkado
30 Aug 2007 6:53 AM
Hello everyone,
I read the post on missing login and I have a similar problem. I have really messed up this time.
I was working on setting up a registered user that pays a monthly fee. I was on the Site Settings, Pages, Security Roles.
I was following the tutorial and thought I did everything the way I was suppose to but then when I tried to test it it didn't give me the payment choice just the free trial option.  Then I must have changed something without thinking.
When I click on the register link it takes me to the home page. How do I get it back to the way it was originally. I don't know what it originally pointed to. I looked in "Pages" but I don't see anything for "Register".  The Login link still works.
If any one can help I really need it..
dinkado
My spouse went to the store to get more memory, I told my honey to get me some too... My brain is full.
dinkado
30 Aug 2007 7:56 PM
Posted By dinkado on 30 Aug 2007 6:53 AM
Hello everyone,
dinkado
I figured it out. It was so easy once I did it.
For any other newbie out there that has this problem this is the solution.
Admin
Site Settings
Advanced Settings
User Page > set to not specified
This is also the place to set what page is displayed upon entering the site as well as several other features. Be very careful when making changes here.
Best wishes,
dinkado
Forums > Users Lounge > Everything Else > Register Missing
