| RE: How can i edit any module from front end by leesykes |
| hello,I have just tested this and can see exactly the same as you, I suspect the core team have set ... |
| RE: EasyCGI help? by leesykes |
| You may want to ask them to reset the correct permissions on your DotNetNuke installation files, som... |
| RE: quick question by leesykes |
| Hello,It will be possible to a degree, but it depends on how both of the skins have been built. You ... |
| RE: EasyCGI help? by Dr Joe |
| I'll let you know how it works out. I think I opened up about 6 tickets with them so far. ... |
| RE: EasyCGI help? by derpir |
| Hi Joe
amazing to say the least!
I will change host to PowerDNN as soon as possible, seems to me t... |
| Amazing - I'm going through this exact same thing with EasyCGI! I managed to successfully instal... |
| Running the local host installation after building the application by saintX |
| My localhost installation of DNN was running blameless. After I oppened the application with VWD it ... |
| RE: quick question by derpir |
| Hello
Is it possible to buy two skins and combine them? for example put one skins visual attributes... |
| RE: Environment Variables by leesykes |
| Thanks for the info, |
| RE: How can i edit any module from front end by sanju_k1421 |
| ok if i added an text html . now i want to fill into that have to log in ,but i want that an... |
| Module not working when logged off. by t.ramya85 |
| Hi friends,I have created two modules which interact with each other and i have kept one module to b... |
| RE: Environment Variables by fandnet |
| There are many ways to use variables like what I was trying to use...But here is how I did it.DotNet... |
| RE: OpenForce '08 by mgordon |
| It was truly a great time. I really feel this year was much better than last year. I hope to ge th... |
| I am creating a simple module that registered users can use to send an email invitation to people wh... |
| I'm not sure that I follow, could you provide an example? |
| RE: Development of modules by leesykes |
| Hello,Glad you find them useful, at the moment there are not any plans to go into Module Development... |
| RE: SQL Server 2008 Documents Module DotNetNuke by leesykes |
| Hello,Thanks for the tip. Yes both connection strings are in correctly and the user has full permiss... |
| RE: Now, portal creation problem by jncraig |
| Since you have other issues with installing modules, etc. I believe that you are correct that it's a... |
| RE: How do I display the current time by jncraig |
| The [CURRENTDATE] skin object has a DateFormat attribute. The examples give MMMM dd, yyyy as a typi... |
| RE: Now, portal creation problem by SupaHoopsa |
| Posted By jncraig on 18 Nov 2008 8:54 AMIf there are other errors related to the database, I would s... |
