Subject: Question about this site...
NFX
17 Aug 2007 12:26 PM
I noticed the "My Account" pages look different than mine. Are you using a custom or third party module? If so which one?
Also I would like my subscription to auto renew, will that happen or do I have to resubscribe manually?
Finally are you using a third party payment provider? I currently use the Ventrian one which works well but I am interested in others.
20 Aug 2007 3:58 AM
I'm using ventrian subscription tools as well. - I created a new page for the my account page and just added the core User Account module to the page.
I have removed all auto renew subscriptions, so you will need to do this manually, this is because people tend to forget about auto subscription payments and may get annoyed if payment is automatically taken.
Forums > Users Lounge > Everything Else > Question about this site...
