Subject: Events module error
essel
14 Aug 2007 8:03 PM
Can anyone tell me how to correct this, please?
Error: Coming Events is currently unavailable. DotNetNuke.Services.Exceptions.ModuleLoadException: Object reference not set to an instance of an object. ---> System.NullReferenceException: Object reference not set to an instance of an object. at DotNetNuke.Modules.Events.SelectCategory.get_SelectedCategory() at DotNetNuke.Modules.Events.EventList.BindDataGrid() at DotNetNuke.Modules.Events.EventList.Page_Load(Object sender, EventArgs e) --- End of inner exception stack trace --
ACTnet
22 Aug 2007 6:17 AM
Hello!
I got the same error message and need help too.
Forums > Users Lounge > Everything Else > Events module error
