Subject: Dnn site on iis 6
dnnuknewbie
24 Jul 2007 5:53 AM
Greetings,
i have placed a site within a virtual directory within iis and have created a separate application pool. I am wondering now whether i should create a separate website for it rather than having it within a virtual directory.
Will this be a simple process of creating a website and then pointing to the folder or will i have to reinstall.
Thanks.
Forums > Users Lounge > Everything Else > Dnn site on iis 6
