Subject: Unable To Login Using IE7 DNN 4.0.3
melanyie
30 May 2007 12:02 PM
We recently migrated our system from one server to another. We have succeefully change the machine key and usernames/passwords in the database.
We are able to successfully login to a DNN as host or admin using Firefox but, when we try using Internet Explorer we get nothing, (not even a bad password response) it just redirects to back to the home page.
Can anyone help.
Thank you.
30 May 2007 1:34 PM
I occassionally get that problem from users on DNN Creative. The solution is usually to just delete all cookies related to the website as they have somehow become corrupted. - Give this a try and see if it helps,
phixate
31 May 2007 1:54 PM
I'm having this same problem. Can't log in with IE but Firefox works fine. I tried clearing my browser's cache, clearing my DNN cache but it still doesn't work. Any ideas?
05 Jun 2007 7:27 AM
could be the security settings in IE preventing the storage of cookies
holisticdnn
04 Sep 2007 7:48 AM
I am having the same problem using IE7 DNN 4.4.0 on multiple computers so I think that clearing the cookies would solve the problem.
Can it be from the DNN version?
holisticdnn
04 Sep 2007 7:51 AM
sorry...
...so I think that clearing the cookies wouldn't solve the problem.
hehe
04 Sep 2007 8:13 PM
If you can't login from multiple machines, I'd double check the machine keys and then entire web.config file.
lwestphal
11 Oct 2007 8:49 AM
Has anyone had any luck resolving this. If so, please post your possible solution. Thanks
11 Oct 2007 9:27 AM
What particular problem are you having? Give us some details and see if we can help solve your problem.
If you can't login after an upgrade, it's most likely a Machine Key issue in the web.config files.
Forums > Users Lounge > Everything Else > Unable To Login Using IE7 DNN 4.0.3
