Subject: visible="false" and validation
lellington
17 May 2007 1:45 PM
Hi All --
So, how do I get this to validate?
Has anyone come across this?
I'm using SOLPARTACTIONS little blue arrow to control admin side of things, but it won't validate unless I remove visible="false".
Anyone know a work around that doesn't require using that drop down box?
THanks
Lisa
Forums > Users Lounge > Everything Else > visible="false" and validation
ok great, glad to help,
