Subject: Anyone know of a good Blog module
markp
10 May 2007 4:57 PM
I have 4.5.1 loaded and my customers are asking for a blog module.  I want to be able to show a summary of recent blogs on the home page and if they click on one , take them to a blog specific page, like myspace does.
Does anyone know of a good one , with decent documentation?
Thank you
Mark
11 May 2007 2:57 AM
I would probably go with www.ventrian.com news articles module.  You can edit the layout of the module using templates and also skin the module. For documentation I created a video tutorial on an earlier version of the module, the look has slightly changed but it should get you started using the module:
http://www.dnncreative.com/tabid/62/Default.aspx
markp
11 May 2007 2:47 PM
Thanks Lee, i checked out his site, I am hoping that since I recently moved to webhosting4life that I can take advantage of the referral program.
Forums > Users Lounge > Everything Else > Anyone know of a good Blog module
