Subject: DNN 4.5 and MSSQL 2000/2005
markp
13 Apr 2007 9:15 AM
I was recieveing a connection error on several of my modules. This is the reply I posted in another forum, when I found out what the solution was.
Leupold thank you for pointing me in the right direction.  I was using a straight text editor, and didnt notice that the legacy section for MSSQL 2005 was commented out!  Therefore even when I replaced the string, it didnt take affect.
I checked the update version of the 4.5 Install and release.config comes with this section commented out  Those of us with Server 2000/2005 need to make sure we move the close to the comment section.
Forums > Users Lounge > Everything Else > DNN 4.5 and MSSQL 2000/2005
