Subject: Broswer Title Bar
markp
11 Apr 2007 2:18 PM
I know I have read this somewhere, checked my book couldnt find it, how do I remove the DNN version from the broswer title bar. I dont want hackers to know its DNN or what verison.
I thought it was a host setting but cant seem to locate it.
Thank you
Mark
12 Apr 2007 7:35 AM
Host / Settings / Display Copyright Tick Box
Forums > Users Lounge > Everything Else > Broswer Title Bar
