Subject: CSS rollover buttons
thebottgroup
06 Mar 2007 10:08 AM
Hi All - Lee youve done a great job - Ive watched most of the tutorials - but am looking to make rollover images using style sheets but am having problems - is there a video of how to to get it done in DNN
I created this file  and it works on an HTML page but can't get it to work in the dnn module - Im new to CSS stuff so please be kind
html cocument
< html>
< head>
< title>My CSS Navigation
< meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
< /head>
< body>
p.navbuttons a:hover, p.navbuttons a:active {
background-color: #white;
color: #FFFFFF;
background-image: url(="/Portals/0/TDsucribeUP.png);
background-repeat: no-repeat;
06 Mar 2007 12:09 PM
There is not a video on how to do this, but you may find the following helps:
DotNetNuke uses a slightly different CSS class naming method, for instance any text placed within the text/HTML module uses the CSS class of normal.
For example, if you add a link into the text HTML module and then rename your CSS to use the following classes:
.normal a {
color: #000000;
text-decoration: none;
background-color:white;
padding: 3px 0px 3px 12px;
width: 80px;
border-top: 0px solid #EEEEEE;
border-right: 0px solid #666666;
border-bottom: 0px solid #666666;
border-left: 0px solid #EEEEEE;
.normal a:hover, .normal a:active
etc.
This will change the details whenever you hover over the Link.
If you watch this video tutorial: Troubleshooting DotNetNuke Skins you will learn the methods for finding out which CSS classes DotNetNuke uses.
Hope this helps, thanks,
Forums > Users Lounge > Everything Else > CSS rollover buttons
