Subject: Separate blogs on same site
anielsendk@gmail.com
01 Mar 2007 10:40 PM
Is it posible to have multiple/separate blogs on the same site.
My goal is to have two pages.
Page 1: blogs created by "internal" users
Page 2: blogs created by "external" users
I want registered users to see both blogs.
I manage to create the two pages and adding the Blog module to both of them..  The problem I have is that they both seem to share the same database.   Meaning the blogs created on page 1 also appears on page 2.
Hope you can help!
08 Mar 2007 5:47 AM
Have you checked out this tutorial: Blog Module
In particular check out these videos:
Video 7 - Applying the blog module configuration options to a real world example - part a
  • How to create a blog page which only staff members can view, post and search
  • How to create a separate page to display a single staff member blog
  • How to delete the blog list
  • Adding 3 further separate blog pages
  • How to add security roles for subscribersA and subscribersB
Time Length: 7min 17secs
Video 8 - Applying the blog module configuration options to a real world example - part b
  • Adding the users to the security roles subscribersA and subscribersB
  • How to configure a blog page to have view permissions of subscribers
  • Demonstrating access as a member of staff
  • Demonstrating access as subscriberA
  • Demonstrating access as subscriberB
  • Demonstrating access as a standard registered user
  • How to delete a blog
Time Length: 6min 50secs
Forums > Users Lounge > Everything Else > Separate blogs on same site
