Subject: Installation error on Live Server
markp
09 Feb 2007 2:48 PM
InvalidOperationException: Failed to map the path '/DotNetNuke/App_GlobalResources
any thoughts?
09 Feb 2007 3:02 PM
not sure. Check the usual suspects:
Permissions are still enabled - when I was uploading new upgrade on DNN C, this is what caught me out.
web.config has all correct settings transferred
markp
19 Feb 2007 10:22 AM
I found a post about this that points to the problem beign the aspnet users permisions. I have followed the instructions with no joy. We are begiining to believe it maybe because our server is running windows 2000 os.
Forums > Users Lounge > Everything Else > Installation error on Live Server
