Subject: list of registered users
DNNFLO
01 Feb 2007 9:25 AM
Hello, first of all, I want to tell you how your site is efficient ! I've found here so many useful information.
I'm looking now for a simple way of extracting the registered users list , for example in an Excel file.
Is it possible directly from the host/admin tools ? Is there a specific module doing that ?
I would like to find a solution in order to avoid direct query on the database server using Enterprise Manager. (The administrators of my DNN sites don't have any SQL background, but they really need to work with this list)
Thanks a lot in advance,
02 Feb 2007 3:40 AM
Glad to hear you find the site useful, its always good to hear.
Have you thought about using the reports module that comes with DotNetNuke? you could program an SQL query into the module and it would display the results on the page. - this would mean however that your administrators would have to copy and paste the data from the page.
Other options would be to explore the listX module - http://dnn.bi4ce.com/?tabid=240
which does allow you to export data to an excel file.
Forums > Users Lounge > Everything Else > list of registered users
