Subject: DNN - jumps around the screen
MWiseman
30 Jan 2007 11:09 PM
Many DNN sites jump around the screen until they settle down. On some sites this happens everytime you open a new page. The official dotnetnuke site is one of the worst offenders.
It looks sort of amateurish. Does anyone know what causes it and how to stop it.
Mark
31 Jan 2007 4:06 AM
Hi Mark,
I haven't come across this before, which browser are you viewing the sites with?
MWiseman
31 Jan 2007 2:35 PM
I am using firefox. Am I the only one with the problem? If I am its kinda reassuring
Mark
02 Feb 2007 3:22 AM
Hi Mark,
I am also using Firefox and have not seen this problem. I have also not seen this problem in Mozilla, IE6 / 7, Opera or Netscape.
I'm not sure what would be causing this problem on your system.
Hope this helps,
Forums > Users Lounge > Everything Else > DNN - jumps around the screen
