Subject: Packaging Videos
DavidWSnow
26 Jan 2007 11:50 AM
Lee could you consider packaging your videos for each issue so that we wouldn't have to unzip them so many times. I suspect that you don't get more compression by zipping them twice or more.
/DaveS
30 Jan 2007 7:54 AM
Hi Dave,
The files are not zipped to gain compression, they are zipped to more easily organise the video files. This ensures that all files are organised in the same way, from the video zip files on the main tutorial page to the video zip files on the issue page. -   If a user has a problem with a file then it is much easier for me to find which file they have problems with. So, I'm afraid I will be still using the same method of packaging the videos.
Forums > Users Lounge > Everything Else > Packaging Videos
