Subject: How can I find a specific class using VWD 2005 express
cipher2079
13 Jan 2007 10:27 PM
Hi lee,
can you give me some tips on how to use the object browser
within VWD 2005 express
for example,
if I want to locate a class called RoleController ( which i assume base on the object browser is part of the dotnetnuke classes)
the namespace points to security and roles class if I am not mistaken (DotNetNuke.Security.Roles)
the solution I use is the "Find and Replace" option however it does not directly find the class Iam looking for it might find a method or property before the actual class
15 Jan 2007 4:12 AM
I have not done any module development work in VWD express, so I would recommend you go to the main dnn forum for tips. - It's one of those things that I keep wanting to do, but keep running out of time,
Forums > Users Lounge > Everything Else > How can I find a specific class using VWD 2005 express
