Subject: Adding Javascript functions
stapes
13 Dec 2006 5:54 AM
I am trying to add some scripts for a Hotel Reservation System to an existing DotNetNuke page. I have edited the default.aspx file and put the functions in the <head> area. I have also tried to add <body onload="setCurrentDate()">, but this gives me a compile error: setCurrentDate is not a member of 'ASP.Default-aspx'. What does this mean?
None of the functions work. Is there any documentation on this anywhere?
Stapes
13 Dec 2006 7:46 AM
Have you checked out this post:
http://www.dnncreative.com/Forum/tabid/88/view/topic/forumid/4/postid/1600/Default.aspx
In addition to the resources mentioned in that post, this skin: Free Skin - Simple Red Leaf CSS Skin uses a javascript function to call up various style sheets which may help you.
Forums > Users Lounge > Everything Else > Adding Javascript functions
