Subject: Refer a Friend
01 Dec 2006 4:57 PM
How did you implement the referral on this page:
http://www.dnncreative.com/Home/ReferaFriend/tabid/103/Default.aspx
I'd like to duplicate something like this on my site.
05 Dec 2006 3:29 AM
check this page:
http://www.dnncreative.com/ModuleDirectory/PromotionModules/tabid/109/articleType/ArticleView/articleId/27/SmartThinkerReferralsReferaFriendforDNN3x.aspx
thanks,
