Subject: screen video creation
eureka
17 Nov 2006 8:34 AM
Hi Lee
I understand that you use Flash to display your video's for Dnncreative  tutorials. But what software do you use to capture the actions of your computer screen and narriation prior to inserting it into Flash?
Lynn
17 Nov 2006 8:41 AM
Hi Lynn,
It's Macromedia Captivate - now called Adobe Captivate and they have just released a new version.
The software automatically creates the flash file for you.
coop3dw
22 Nov 2006 9:03 PM
Just a suggestion, but I use Wink for creating flash tutorials.  I'm sure it's no where near as robust as Captive but it is free and it does a good job
http://www.debugmode.com/wink/
Forums > Users Lounge > Everything Else > screen video creation
