Subject: image module
acda150
09 Nov 2006 10:40 PM
Hi every one!
Coulde you please explain me how to upload image module from the net?
cheers
13 Nov 2006 4:19 AM
The image module is no longer included with 4.3.x - this has been replaced by the media module which is included with 4.3.x
thanks,
