Subject: DotNetNuke deployment
acda150
08 Nov 2006 9:22 PM
When i try to brouse dotnetnuke poortal using ip address or domain name, url always goes to local host.
Could you please explain me how to solve this problem?
cheers
Ash
09 Nov 2006 2:52 AM
If I understand you correctly try this:
Log in
Go to the admin menu / site settings
scroll down
Portal Aliases
Click on Add New HTTP alias
Enter your website address: ie. www.mywebsite.com (do not enter http://)
Click on Update
When you enter www.mywebsite.com into your browser, your DNN portal should now pick it up. (Of course your hosting provider also needs to be pointing the domain name to your DNN installation)
acda150
12 Nov 2006 10:53 PM
Hi Lee,
Thanks for that, it is working fine now.
Ash
Forums > Users Lounge > Everything Else > DotNetNuke deployment
