Subject: Register Control Customisation
sansanwal
05 Nov 2006 9:34 PM
How could have the layout of registration page same like one of DNN creative?
By default this control display one row for each property. How to display properties in 2 column table.
Cheers,
Sanjay
06 Nov 2006 3:46 AM
This is because DNN C is currently using v 3.2.2 which is how it displays the registration page. For DNN v 4.3.x you have the singular column display.
The only way around this is to create your own custom registration module.
Forums > Users Lounge > Everything Else > Register Control Customisation
