Subject: Register Control Skin
sansanwal
05 Nov 2006 8:50 PM
How could I change the register control skin? It is one opened when user click the REGISTER link.
I don't find any settings for this control.
06 Nov 2006 3:44 AM
If you want to have a completely separate skin for the registration page:
Create a new page
Add the User Account module
Go to the page settings, select the skin you require for this new page
Go to Admin / Site Settings / Advanced Settings / Page Management
User Page:  - select the new page that you have just created
Forums > Users Lounge > Everything Else > Register Control Skin
