Subject: Looking for a development partner
chrisschofield
03 Nov 2006 3:37 AM
My name is Chris Schofield and my company is moving heavily into DDN portals. Based in Oxfordshire.
I need partnership resources for :
DNN Skinning
Page design, layout and build
Catalook set up and build
Multimedia creatives
I have lots of potential business to place with a reliable partner
Would prefer to work with someone within driving distance.
Many thanks
Regards Chris
Forums > Users Lounge > Everything Else > Looking for a development partner
