Subject: capture full page as image
eureka
20 Oct 2006 1:16 PM
Hi Lee
What software do you recommend in order to create an image of a full web page or skin?
The software I am currently using is capable of capturing an image of the screen, but sometimes this is not enough for the full page.
Lynn
22 Oct 2006 6:47 AM
Hi Lynn,
All I do for capturing images of a web page / skin is to press the PrtSc button and then open an image editor programme such as Fireworks and press CTRL+V to paste in the image.
If I need to create an image of a long page, I just create several screen captures and then paste them together in Fireworks to create one large image.
dreww
24 Oct 2006 2:28 PM
I recommend Webshot, a free utility to grab a scrolling screenshot of a web page. in the TestComplete blog I wrote about how to use it with software testing.
gymnasticsmedia
24 Oct 2006 4:44 PM
NICE FIND! I was just about to suggest setting your monitor to a really high resolution, then capture the page, but WebShot looks awesome! Be trying it tonight when I get home.
GymnasticsMeida.com
The Ultimate Portal for the Ultimate Sport
Forums > Users Lounge > Everything Else > capture full page as image
