Subject: Adding Media Content to User Profile
dave0160
10 Oct 2006 10:21 AM
I have been working on my registration page and have got it pretty much how i would like it, but one feature i would like to offer my users is the ability to add media to their profile.
What is the best way to go about this?
Any help will be greatly appreciated
Dave Stacey
10 Oct 2006 10:39 AM
Hi Dave,
Unfortunately there is not an option for uploading media to the registration form.
Your options are to create your own custom registration module, or perhaps to make use of another module such as the repository module (but this will not incorporate with the registration form).
Forums > Users Lounge > Everything Else > Adding Media Content to User Profile
