Subject: error: registration is not available
cipher2079
01 Oct 2006 12:36 PM
Hi lee,
I just started working on issue 13 and got an error when trying to register a new
user. i tried finding an answer for this but could not find though I will keep, hopefully you can help me.
08 Oct 2006 10:23 AM
The only time I have come across problems is when you delete some of the default form elements from manage profile properties.
The workarounds to not deleting these elements are outlined in the tutorial.
cipher2079
09 Oct 2006 12:12 PM
exactly what tutorial? error: registration is not available
10 Oct 2006 7:27 AM
hello,
In this tutorial: (Creating a custom registration page)
(6 videos - 53 min)
Forums > Users Lounge > Everything Else > error: registration is not available
