Subject: simple red leaf: where have the context menu's gone?
mschipperheyn
18 Aug 2006 7:53 AM
I've just implemented the Red Leaf skin. In admin mode, I see the dotted lines around the containers, but the context menu has disappeared.
Any ideas on this?
Cheers,
Marc
18 Aug 2006 5:38 PM
Do you mean the menu where you can access the module settings?
If so, this is now a drop down list at the top of the container. - You select an item from the drop down list and then click on the Go arrow to load it.
This is because at the time of creating the skin, the Solpart menu was not compatible in transitional mode, but from first tests using DNN 4.3.4 it appears as though Solpart is now compatible.
Forums > Users Lounge > Everything Else > simple red leaf: where have the context menu's gone?
