Subject: Changing the House Menu??
ollep
10 Oct 2008 8:17 PM
Hi Lee
I can’t see sub-menu’s in some of the horizontal House Menu skins?
I recall you where talking about “static” layout in some tutorial. But is there an easy way to change them to have drop down list for sub-menu items?
I’m playing with an “Andreas09” sin here:
www.mudgeerabahilltons.com
Thanks!!!!
Olle....
13 Oct 2008 9:35 AM
There is not an easy way to change them to hover over submenu items. When using the house menu, I always configure submenu items to display as a separate list in the left or right pane, as you can see on many of the pages on DNN creative.
If you wish to use a hover over menu I would suggest you use the snapsis CSS menu, or the DNN Nav menu.
ollep
14 Oct 2008 4:34 PM
Thanks lee.
The configuration for the separate sub-menu-item list, do you show that in a tutorial somewhere?
Snapsis seems a bit ‘pricy’ compared to the excellent job the House Menu does for free.
The DNN Nav, is that CSS? If not it must be harder to configure with background images, colors etc?
Also, I was looking for it on the DNN Site but couldn’t find a download?
Cheers
Olle...
15 Oct 2008 3:14 PM
DNN Nav is available with the default install of DotNetNuke and already installed. - Just look at the code for the MinimalExtropy skin in 4.9 for an idea.
For sub menus in House Menu check out:
How to create Horizontal CSS menus in DotNetNuke using the HouseMenu
This is for horizontal sub menus, but the same can be applied for vertical sub menus,
Subscribers do get a discount on snapsis, check out the discount codes available at the top of this forum,
thanks,
Forums > Users Lounge > Everything Else > Changing the House Menu??
