Subject: Pop up window
yerann
06 Oct 2008 10:09 PM
Whenever a page loads in DNN i would like a pop up window to display.  This pop window ask the user if they want to be redirected to another page.
This pop up would display for every page in my website.
Has anybody come across this problem before and what is the best solution.
Yenn
07 Oct 2008 7:43 AM
I believe that ZLDNN (zldnn.com) has a module that will pop up a page or a module. I've not tried it, but I've used their Module Wrapper module, and know that it is good.
yerann
10 Oct 2008 4:56 PM
