Subject: How can I change the background of a website
cipher2079
05 Aug 2006 11:55 AM
I would like to change the background of a website. I understand that it depends on the skin. I tried changing it through admin site setting and everything stood the same. Is there any specific way to accomplish this?
07 Aug 2006 4:26 AM
It all depends on how your skin is designed. - Generally though you will be able to set this within your skin.css file.
You could try changing the body class - ie:
body {
background-color: #333;
But you may find that if you have designed the skin using tables that this will not have an effect. - You then need to have a look at any classes assigned to your tables and see if you can change the background color for those classes. - To test this out you could use:
body, tr, td {
You may find you have assigned a CSS class such as this below to one of your main tables:
.skinmaster {
Hope this gives you a starting point, thanks,
Forums > Users Lounge > Everything Else > How can I change the background of a website
