Subject: Calendar Module Search.
ollep
01 Oct 2008 11:34 PM
Apartment Booking Project.
See Details Here:  http://www.goldcoastwebwiz.com/dotnetnuke/grape
Where can I find a calendar booking module?
I want a graphic image of a calendar, ideally, where I can tick off dates booked in individual apartments.
Or better still, select the dates for a specific apartment and the dates gets blocked off the Calendar.
Any database / booking modules would be interesting to have a look at.
Thanks Guys.
Olle..
PS. Currently looking at the Indoolab 2.2 Module, it’s an excellent tool with an endless row of features, just missing this little bit for our project.
02 Oct 2008 3:46 AM
you could try http://www.smart-thinker.com/ - they have a try before you buy policy.
Forums > Users Lounge > Everything Else > Calendar Module Search.
