Subject: Stuffed up LocalHost and SQL
ollep
29 Sep 2008 11:24 PM
After reinstalling the SQL Server I get the following error when I attempt to access my local DNN Installation:
Generating user instances in SQL Server is disabled. Use sp_configure 'user instances enabled' to generate user instances.
Exception Details: System.Data.SqlClient.SqlException: Generating user instances in SQL Server is disabled. Use sp_configure 'user instances enabled' to generate user instances.
I checked around and they talk about sp_confgure everywhere.
But where do I find it and change the settings?
Cheers
Olle...
ollep
30 Sep 2008 6:59 AM
OK, Nine hours later and Getting nowhere.
I’ve read 100 forum post and Not One can say how find “SP_Configure” Settings or how to Enable “User Instances”
Just did Issue32 of the Tutorials. Setting up the Database connection and creating Queries works fine – but I can’t get access to the Local Host installation:
Here’s the error – and I have tried reinstalling user a couple of times.
Login failed for user 'ollepersson'. The user is not associated with a trusted SQL Server connection.
I then tried to reinstall DNN 4:8:4 on my XP-Pro – in a different folder.
All worked fine until I tested the database connection and got this error.
Connection Error(s):
Index #: 0
Source: .Net SqlClient Data Provider
Class: 14
Number: 15383
Message: Generating user instances in SQL Server is disabled. Use sp_configure 'user instances enabled' to generate user instances.
Any Ideas Please??
Olle…
ollep
30 Sep 2008 7:30 AM
Finally!!!!!!
I found this string in a forum:
'user instances enabled' is a server option of SQL Express, you can right click VS->new a Data Connection to the SQL Express instance->new a query->execute the following statements:
sp_configure 'user instances enabled', 1; RECONFIGURE
Congratulations
Congratulations, you have successfully installed DotNetNuke.
God Night!!!
30 Sep 2008 8:48 AM
Glad that you got this solved.
01 Oct 2008 8:35 AM
Yes thanks for posting the info, I'm sure others will find it useful,
Forums > Users Lounge > Everything Else > Stuffed up LocalHost and SQL
