Subject: Forum has vanished
Gobby
29 Sep 2008 12:40 PM
Hi All, Newbie here needing some major help! I run a phpnuke forum at www.blackcountrygob.com which was set up for by someone who i am no longer in touch with. This morning I tried to get onto it but all I am getting is a blank screen. One member who is a mod can access it after doing so via a mesage notification link and says she is the only one online. I managed to access it on IE ( I usually use Opera) via a google cached page but only into my member account. i cannot get access to my admin section i.e /admin.php I know absolutely nothing about php etc and so am just stuck. The site is a non profit community site with over 200 members and has been running since january and already has over 800,000 pageviews so I don't want to lose it also we have a genealogy section with over 10,000 pieces of info. Before you ask....No i don't have a backup
29 Sep 2008 4:11 PM
I'm afraid our expertise is in DotNetNuke rather than PHP nuke, you may want to try one of the PHP forums, good luck, thanks
Forums > Users Lounge > Everything Else > Forum has vanished
