Subject: Newsletter Module
ollep
29 Sep 2008 6:22 AM
Hi Lee
Just found your Newsletter Tutorial, Issue 15.
But I can't find the Newsletter Module?
Doesn't seem to be on the DNN Site listing.
Is it still avaialble?
Cheers
Olle...
29 Sep 2008 7:52 AM
It's on the Admin tab.
ollep
29 Sep 2008 3:01 PM
Thanks Joe.
Gee, that was a hard one.
I had to install a skin onto a portal to figure it out!
Apparently, it is called “Newsletter” in the SolePart Menu.
And it is called “Bulk Email” in the House of Nuke Menu!!
Just in case anyone else is going crazy looking for “Newsletter” in the admin list.
Cheers
Olle…
29 Sep 2008 10:17 PM
Sorry, I should have mentioned that. Actually, I believe that Bulk Mail is the real name of the tab ...
Forums > Users Lounge > Everything Else > Newsletter Module
