Subject: Holiday Booking Site - Modules?
ollep
29 Sep 2008 12:58 AM
Hi Wizards.
Lee, Lynn, Mitchel and others…..
Please feel free to forward this E-mail to anyone you may thing has something suitable for sale.
We are looking at a project involving an E-commerce site, it involves automation of booking and invoicing of holiday rental apartments.
I have put the first part of the customer request on the following site, this part looks simple enough and pretty much aligned with Dot Net Nuke Standard.
http://www.goldcoastwebwiz.com/dotnetnuke/Grape
Questions might be:
DNN Modules for displaying DataBase Query results?
Invoicing Modules?
Editing Forms Automatic data retrieval from the DataBase?
Looking forward to hear what you have available
I will be looking at “part 2” and add that request to the site as well.
Cheers….
Olle…
PS. Lee; So which tutorials do I need to run through for this project?
PPS, We will be commissioned by the copyright holder, so that issue is taken care of.
29 Sep 2008 3:57 PM
You may want to have a look at the modules by r2i, in particular ListX
Forums > Users Lounge > Everything Else > Holiday Booking Site - Modules?
