Subject: Question about video tutorial
derpir
27 Sep 2008 5:08 AM
hello sorry about the BOLD text above, but I am wondering if there is any tutorial video related to this issue?
I cant find one...
regards
Alex
28 Sep 2008 9:11 AM
You might want to take a look at:
If you are looking for a very customized registration process, Data Sprins makes Dynamic Login and Dynamic Registration.
Forums > Users Lounge > Everything Else > Question about video tutorial
