Subject: Database question
derpir
26 Sep 2008 6:19 PM
Hello
I am building a sportwebsite, shaped like a "sports magazine", but I have some questions about DB building. Is it absolutely necessary to build a DB from scratch? How much DB-work is necessary for me to build? Can I build a website based on DNN technics without building a traditional DB with tables and stuff?
how much does DNN support regarding DB?
do I make sense?
Regards
Alex
26 Sep 2008 6:22 PM
Alex,
DotNetNuke absolutely requires a database. That's they way that it works.
But, the good news is that YOU don't have to build the database. As part of the installation, you'll need to create an empty database and then use DotNetNuke's Wizard to connect to it. DotNetNuke and modules build out the database.
In fact, I believe that one can build a perfectly nice website without knowing a thing about databases or HTML. Of course, the more you know, the more you can do. But you don't have to!
derpir
26 Sep 2008 6:32 PM
Hello
Thank you for your incredibly fast and informative answer, your answer was exactly what I was looking for. I have done all the preparation as you mentioned about creating an empty DB.
thanks for your answer
//Alex
29 Sep 2008 11:14 AM
if you are just starting out in DotNetNuke, these may be useful:
derpir
30 Sep 2008 1:01 AM
I have been developing for about 3-4 weeks but only on weekends, I am a newbie to the DNN technics.
Regards
Alex
Forums > Users Lounge > Everything Else > Database question
