Subject: Problem with pure CSS skins
Revide
26 Sep 2008 2:59 AM
I need a skin that looks like this but have a background color vertically fading from the top down with a height that reaches down under where the content starts. The problem is the shadow dropped by the content on both sides.
I’ve tried saving the shadow as a transparent PNG and use it with the PNG transparency fix for IE, but that fix doesn’t work very well with DNN. It randomly disables hyperlinks and makes the FCK editor disappear.
How can I do this layout without using javascript and still have a pure CSS skin, or is there a DNN fix for the PNG issue with IE?
26 Sep 2008 9:36 AM
I've not had much success with transparent PNGs, if you find some information, please let us know, thanks,
Forums > Users Lounge > Everything Else > Problem with pure CSS skins
