Subject: UDT Search customization
cozahost
25 Sep 2008 9:53 AM
Hi there
I am hoping to create an accommodation / venue browse using the User Defined Table module.  I want to know to create a search filter so that visitors can select a province, accommodation type, etc. and the hit the UDT database to return rows.
Here is an example of a search method that I would like to emulate:
http://www.aatravel.co.za/search.jsp
Is there anywhere where I can learn more about extending/customizing the UDT search function?
26 Sep 2008 9:02 AM
if you are needing to create something with as much search flexibility as that site, I would look outside of the UDT module and have a look at a module such as r2i listx.
Forums > Users Lounge > Everything Else > UDT Search customization
