Subject: More Internet Explorer Problems
ollep
15 Sep 2008 8:27 PM
Just did a new site, please check the wild colors and comment.
http://www.goldcoastwebwiz.com/dotnetnuke/q1
The header image has a part transparent background, so I did it in “*.png” format.
This worked in IE 7 and in Firefox, while IE 6 put a background on it????
I changed it to “*.gif” and it worked fine, but the quality of the text is very poor compared to the “.png” format.
I tested again with the “GrapeVineBanner  .png” further down, that too is partly transparent in IE7, while it has a grey background in IE 6.
Any Ideas???
Olle…
24 Sep 2008 4:30 AM
Did you find a solution? pngs, transparency etc in IE6 has always been problematic, might be worth googling around for tips
ollep
24 Sep 2008 6:38 AM
Thanks Lee
Well, "GIF" works, but the details on images becomes crappy.
I ended up putting a background on the image that match the site background, then I can use either "png" or "jpg".
Forums > Users Lounge > Everything Else > More Internet Explorer Problems
