Subject: issue 36 I would like to install the skin
cipher2079
03 Sep 2008 8:54 PM
I would like to install the skin, do i have to find the video to install skins learn (remember), if i do then thats double work for me which is okay though it would be much easier for the "user/subscriber" to have everything include in the video
04 Sep 2008 4:36 AM
Yes to install the skin, download it from here, instructions are included on that page:
Lazy days - Free DotNetNuke CSS Skin
I do not tend to repeat how to install skins etc. in a video as it would be repeating content that has already been covered and would vastly extend the length of a video tutorial,
Forums > Users Lounge > Everything Else > issue 36 I would like to install the skin
